OFFSET command
Creates parallel copies.
Icon:
Alias: O
Creates parallel copies of 2D entities and 3D solid faces.
Note: The OFFSETGAPTYPE system variable determines how
potential gaps between segments are treated when polylines are being
offset.
Note: The SELECTIONMODES system variable determines how
potential conflicts are handled.
Note: When curved entities are offset, the command changes the
radii of the copies.
Method
There are four methods to create an offset:
- Enter offset distance
- Through point
- Erase
- Layer
Options within the command
- Specifies the distance between the original entity and its parallel copy.
- Both Sides
- Places offset copies on both sides of the entity.
- Multiple
- Repeats the command until you press ESC.
- Through point
- Specifies the offset distance by picking two points.
- Multiple
- Erase
- Deletes the source entity after the offset operation.
- Layer
- Specifies the layer on which to place the copied entity.
- Current
- Places the offset entity on the current layer.
- Source
- Places the offset on the same layer as that of the source entity.
