ORTHOGONAL command
Toggles the ORTHOMODE system variable.
Alias: OR, ORTHO
Toggles the ORTHOMODE system variable to specify if the cursor is constrained to dragging at 90 degree angles. You can launch this command at the Command prompt or within another command by preceding it with an apostrophe: 'ORTHOGONAL.
  • On: turns on the ORTHOMODE system variable.
  • Off: turns off the ORTHOMODE system variable.
  • Toggle: changes the ORTHOMODE system variable to the opposite of the current setting.
