-PDFSHXTEXT command
Converts SHX geometry imported from PDF files into multiline text entities via Command line.
Icon:
Note: The command is available on Windows only.
Method
Select the curves you want to convert to Mtext. To change the settings for converting, choose the SEttings option before selecting the curves. After you configure the settings, press Enter and proceed with the selection.
Note: The command uses the LSTM OCR engine in Tesseract 4 to convert SHX geometry to MText entities. Results may vary, and manual correction can sometimes be faster.
Tip: For the best conversion results:
- Make sure that only SHX geometry is included in the selection.
- Add a language and SHX font that matches the geometry.
- Work in small sections to identify issues more easily and minimize the risk of selecting unintended geometry.
Options within the command
- SEttings
- Configures the settings for converting imported SHX geometry to text entities.
- Add font
- Adds an SHX font to the comparison list. Type the font file name without the quotation marks or .shx extension.Important: The SHX file must be stored in the Fonts folder in the BricsCAD installation directory.
- Remove font
- Removes an SHX font from the comparison list.
- Threshold
- Specifies the required percentage (1-100%) of geometric alignment with a font before text replacement.Note: Use a lower value to generate text even if some characters are not recognized, or use a higher value to prioritize choosing the font that best matches from the comparison list.
- Layer
- Specifies whether the resulting MText is created on the current layer or on the layer of the original geometry.
- Current
- Adds the MText on the current layer.
- Geometry
- Adds the MText on the geometry layer.
- Best match
- Allows you to choose whether the best mach or first match is chosen when selected fonts are compared.
- Best
- Selects the best match that passes the recognition threshold.
- First
- Selects the first match that passes the recognition threshold.
- LIst fonts
- Displays the fonts that are part of the comparison list in the Prompt History window.
- laNguage
- Configures the language training data set.
- Add language
- Adds a language training data set. Type the data file name without the quotation marks or .traineddata extension.Note:
- English and the language of the localised BricsCAD installation are always included.
- Additional data sets can be downloaded at Tesseract documentation. Place them in C:\ProgramData\Bricsys\PdfShx and include them in BricsCAD using Add language option.
- Remove language
- Removes a language training data set.
- Default language
- Sets the default language.
- List languages
- Shows all added language training data sets.
