-POINTCLOUDREFERENCE command
Loads point clouds from cache or inserts new point clouds into the current drawing via Command line.
Method
Import a new point cloud or load from cache.
Options within the command
- Cache
- Allows you to enter the index of the point cloud to attach it to the current drawing.Note: The valid cached point clouds are listed in the Command line history.
- New
- Attaches a new point cloud to the current drawing.
Specify the point cloud input file or folder to preprocess.
- Enter insertion point
- Allows you to enter the insertion point coordinates or specify it on the screen.
- Rotation angle
- Allows you to enter the rotation angle or specify it on the screen.
- Scale factor
- Allows you to enter the scale factor or specify it on the screen.
