-POINTCLOUDREFERENCE command
Attaches point cloud files to the current drawing.
Attaches point cloud files to the current drawing through the Command line.
Method
There are two methods:
- Import a new point cloud.
- Load from cache.
Options within the command
- Cache
- Allows you to enter the index of the point cloud to attach it to the current drawing.Note: The valid cached point clouds are listed in the Command line history.
- New
- Attaches a new point cloud to the current drawing.
- Enter translation vector
- Allows you to enter the translation vector coordinates or specify it on the screen.
- Rotation angle
- Allows you to enter the rotation angle or specify it on the screen.
- Scale factor
- Allows you to enter the scale factor or specify it on the screen.
