PAGESETUP command
Opens the Drawing Explorer dialog box with Page Setups selected.
Icon:
Opens the Drawing Explorer dialog box with Page Setups category selected to view and modify page setups in the current drawing.
Context Menu Options
New
Loads additional page setup definitions into the drawing. Displays the New Page Setup dialog box (see the New Page Setup dialog box article).
Delete
Deletes page setup definitions from the drawing. The following page setup definitions cannot be deleted:
  • The Model tab
  • The last layout
Edit Page Setup
Edit the selected page setup. Displays the Page Setup dialog box. Here you can edit the properties of the selected page setup (see the Page Setup dialog box article).
Rename
Renames the selected page setup.
Note: The following page setups cannot be renamed:
  • The Model tab
  • The Layout tabs
Select All
Selects all page setup definitions.
Invert selection
Deselects the current selection and vice versa.
