PARAMETERSPANELCLOSE command
Closes the Parameters Manager panel.
Closes the Parameters Manager panel to hide it from the current workspace. If the Parameters Manager panel is stacked when you close it, the Parameters Manager panel tab or icon is removed from the stack.
Related commands
  • PARAMETERSPANELOPEN command
Related information
  • Library panel
  • Panels
  • Parameters Manager panel
  • Workspaces
