PASTEORIG command
Pastes entities from the clipboard into a different drawing.
Icon:
Pastes CAD entities from the Clipboard into a different drawing using the coordinates of the entities in the source drawing. PASTEORIG comes from paste at original coordinates.
Note:
- This command does not paste entities back into the source drawing.
- Before you can use this command, first use the COPYCLIP or COPYBASE command to copy entities from the current drawing.
- The PASTEORIG command works concomitantly with the INSUNITS system variable. The INSUNITS system variable must have the same value in both source and destination drawing.
