PASTEORIG command
Pastes entities from the clipboard into a different drawing.
Icon: ![]()
Note: Before you can use this command, first use the COPYCLIP or COPYBASE command to copy entities from the current drawing.
Note: The PASTEORIG command works concomitantly with the INSUNITS system variable. The INSUNITS system variable must have the same value in both source and destination drawing.
Pastes CAD entities from the Clipboard into a different drawing using the coordinates of the entities in the source drawing. PASTEORIG comes from paste at original coordinates.
Note: This command does not paste entities back into the
source drawing.
