PDFADJUST command
Adjusts graphical properties of a PDF underlay.
Icon:
Adjusts the face, contrast and monochrome level of one or more PDF underlays attached to the current drawing.
Note: It can be easier to use the Properties panel’s Underlay Section to adjust the parameters.
Options within the command
- Fade
Sets the fade setting of the PDF underlay(s).
- 0: minimum fade: Underlay PDF is fully displayed
- 100: maximum fade: Underlay PDF is barely visible
- Contrast
Sets the contrast setting of the PDF underlay(s).
- 0: minimum contrast: both dark and light elements are displayed medium gray
- 100: maximum contrast: dark elements are displayed dark, light elements are displayed light
- Monochrome
- Toggles the monochrome setting of the PDF underlay(s).
- Yes
- Turns colors into shades of gray.
- No
- Keeps the PDF as-is.
