PDIM command
Creates dimensions as ACM entities. It is an AMPOWERDIM command.
Icon:
Method
Select the objects to create dimension and specify the point for its location. The Edit Dimensioning dialog box opens to define the parameters of the dimension.
Note: For more information about the dialog box, see the related article Edit Dimensioning dialog box.
- There are two use cases to activate the mechanical entities:
- When creating a new drawing that contains mechanical entities:
- Set the LOADMECHANICAL2D system variable to ON (1).
- Start a new drawing using a Mechanical2d template.
- When opening a drawing that contains mechanical entities:
- Open an existent ACM drawing and start special symbols creation.
Note: These dimensions are compatible with the legacy AutoCAD® Mechanical application.
Note: The dimensions will be added to the AM_5 layer.
Note: After opening a drawing that contains mechanical entities, filling other drawings with mechanical-related data will be done on-demand in contrast to previous versions. It will be possible when a user copies the mechanical-related entities to the vanilla drawing. In case of copying entities that are not related to the mechanical data, a vanilla drawing will not be filled with mechanical data.
Note: When you open a drawing that contains mechanical entities, but the LOADMECHANICAL2D system variable is OFF, a warning bubble is displayed at the status bar that describes the situation and provides a hyperlink to immediately enable and load the mechanical 2d modules.
Options within the command
- Linear
- Creates a linear dimension.
- Aligned
- Creates an aligned dimension.
- Angular
- Creates an angular dimension.
- Radial
- Creates a radial dimension.
