POINTCLOUDCLASSIFY command
Assigns classes to each point in a point cloud.
Icon:
Requirements
Important: The Point Cloud Classifier runs on Windows only.
  • Your system's GPU needs to be CUDA compatible.
    Note: You can check if your GPU is CUDA compatible here.
  • Make sure that the latest NVIDIA driver is installed and running.
  • The point cloud is preprocessed in HSPC format.
Preparing the classifier libraries
  1. Download the classifier libraries from here.
    Note: BricsCAD uses the same classifier libraries for V26 and V27.
  2. Unzip the archive.
  3. Copy the content of the folder to the BricsCAD installation folder:
    • Select all the DLL files and the UserDataCache folder inside the classifier libraries, then drag and drop these over the installation folder. All the DLL files will be copied, and the UserDataCache folder will be updated, with the PCC models folder copied inside it.
    • Alternatively, you can first copy and paste all the DLL files inside the classifier libraries to the installation folder, then copy and paste the PCC models folder to the UserDataCache folder inside the installation folder.
    The BricsCAD installation folder's default path is: C:\Program Files\Bricsys\BricsCAD V27 en_US.
    Important: You need to re-run BricsCAD after you copy the classifier libraries.
If all the above requirements are met and libraries correctly copied, the POINTCLOUDCLASSIFY command will run the classifier.
Method
There are six different models to use with the classifier:
  • indoorBasic has 10 basic classes for indoor scans (walls, ceiling, floor, windows, doors, clutter, etc.).
  • indoorSimplified has 20 classes for indoor scans (basic classes + Inclined roof, Roof Equipment, Steel structure, Railing, etc.).
  • indoorFull has 40 classes for indoor scans (simplified classes + Pipe installation, Wire installation, Radiator, Plumbing, etc.).
  • Outdoor has 5 classes for outdoor scans (Terrain, Vegetation, Building, Paved road - hardscape, Noise).
  • Roads (starting with V25.2.03) has 30 classes, used for classification of point clouds typically captured via a scanner installed on a car (Vegetation, Buildings, Road surface, Curbstone, Guard rails, Sign posts, Vehicles, etc.)
  • Construction (starting with V25.2.03) has 15 classes, used for classification of point clouds captured from a construction site (Vegetation, Building, Road and hardscape, Fencing, Construction material, Trenching, etc.)
Launch the command, select a point cloud entity and select the classification model. The classifier starts running in the background.
If the selected point cloud already contains classification information, the command overwrites this information. The Overwrite class dialog box appears to ask for confirmation to continue.
Note: You can stop the classification process from the Point Cloud Cache Manager (POINTCLOUDREFERENCE command), which displays a progress bar and a Cancel button near the name of the point cloud.
When the process ends, the results appear in the Point Cloud Manager panel under Classes (POINTCLOUDMANAGERPANELOPEN command).
Note: For indoor models, the results are more accurate if room information is available. To obtain room information, follow these steps:
  1. Run the POINTCLOUDDETECTFLOORS command to detect the floors in the point cloud. The detected floors are listed in the Point Cloud Manager panel under Building.
  2. (Optional) To edit the selection of points assigned to a floor, right-click the floor listed in the Point Cloud Manager panel and select the Modify option from the context-menu (see also the POINTCLOUDMODIFYFLOOR command article).
  3. Run the POINTCLOUDDETECTROOMS command to detect rooms in the selected floors. The results appears in the Point Cloud Manager panel, under Building.
Options within the command
Select model
Allows you to select one of the classification models.
indoorBasic
Classifies point clouds using basic indoor classes.
indoorFull
Classifies point clouds using full indoor classes.
indoorSimplified
Classifies point clouds using simplified indoor classes.
Outdoor
Classifies point clouds using outdoor classes.
Roads
Classifies point clouds using road classes (starting with V25.2.03).
Construction
Classifies point clouds using construction classes (starting with V25.2.03).
Select classification mode
Allows you to select the preset configuration for the classifier.
Speed
Prioritizes speed over quality in the classification process.
Quality
Prioritizes quality over speed in the classification process.
