POINTCLOUDEXPORT command
Exports the visible parts of a point cloud to a PTS, HSPC or a LAZ file.
Icon:
Saves the visible point cloud data from the current drawing to the specified file format [Pts/Hspc/Laz].
Note:
- The HSPC file format is a proprietary format developed by Hexagon VCH (Visual Computing Hub).
- When exporting to the HSPC file format, bubbles are also included.
Options within the command
- Pts
- Exports the point cloud data in PTS file format.
Select a destination folder and type the name for the exported point cloud file.
- Hspc
- Exports the point cloud data in HSPC file format.
Select an empty destination folder. Then, type the name for the exported point cloud file in the Command line.
- Laz
- Exports the point cloud data in LAZ file format.
