POINTCLOUDGEOGRAPHICLOCATION command
Sets the geographic location based on point cloud.
            Sets the geographic location based on point cloud; sets point cloud transform based on geographic location; relatively aligns two point clouds.
Note: Only LAS and LAZ file formats can make use of this functionality.
        Method
There are three methods:
- Geolocation
 - Transform
 - Relative
Options within the command
- Geolocation
 - Allows to set a geographic marker in the DWG based on a point cloud with geographic location.
- Transform
 - Updates the point cloud transform based on a geographic location in the DWG, as well as the geographic information in the point cloud.
- Relative
 - Relatively aligns two point clouds if both contain a geographic location.
