POINTCLOUDNORMALS command
Calculates normals using the structured normal calculation after preprocessing.
Calculates normals for structured point clouds (have bubbles) already available in the cache in HSPC that do not have normal vectors yet. The calculated normals will be written to the HSPC file.
Note: A pop-up message appears when the calculations are finished.
