POINTCLOUDSHOWBUBBLES command
Toggles the display of point cloud bubbles.
Note: You can change the bubbles size in the Properties panel.
Options within the command
Yes
Displays the bubbles.
No
Does not display the bubbles.
Related commands
  • ATTACHMENTSPANELOPEN command
  • POINTCLOUDATTACH command
  • -POINTCLOUDATTACH command
  • POINTCLOUD command
Related information
  • Properties panel
