PROJECTGEOMETRY command
Projects 2D geometry.
Icon:
Projects 2D geometry onto regions, surfaces, or 3D solids to create additional edges (line work).
(1) 2D entity; (2) 3D solid; blue line = projection direction; pink tube = projection; yellow curves = new edges
Options within the command
- set PROjection direction
- Defines the projection direction. By default, 2D geometry is projected orthogonally onto the receiving entity.
- View
- Sets the projection direction perpendicular to the current view orientation.
- UCS
- Uses the Z-axis of the current UCS.
- Points
- Specify the start and end point of the projection direction.
