PROPERTIESCLOSE command
Closes the Properties panel.
Alias: PRC
Closes the Properties panel to hide it from the current workspace. If the Properties panel is stacked when you close it, the Properties tab or icon is removed from the stack.
Related commands
  • PROPERTIES command
  • QSELECT command
Related information
  • Panels
  • Properties panel
  • Customizing the workspace
Octave
