-RENAME command
Renames entities via Command line.
Alias: -REN
Renames named entities via the Command line, supporting wildcards to adjust the entity selection.
Note: In the replacement pattern, the asterisk (*) wildcard expands to the end of the string (the wildcard is handled as max greedy). Thus, patterns like '
*-old' (source pattern) and '*-new' (replacement pattern) cannot be used to rename or batch-rename entities (for example, renaming 'layer1-old' and 'layer2-old' to 'layer1-new' and 'layer2-new'). For that, a LISP routine is needed.Important: It is not possible to change the names of attached files, such as images and external references, nor the following names:
- Layer "0"
- Linetype "ByBlock", "ByLayer", or "Continuous"
- Text style "Standard"
- Dimension style "Standard"
- Multiline style "Standard"
- Visual style "2DWireframe"
- Material "Global"
- Page layouts that have * as a prefix and suffix, such as *Model*
- View detail style "Metric50"
- View section style "Metric 50"
Options within the command
- Block
- Renames blocks.
- Dimension style
- Renames dimension styles.
- LAyer
- Renames layers.
- LineType
- Renames linetypes.
- text Style
- Renames text styles.
- Table style
- Renames table styles.
- Ucs
- Renames user-defined coordinate systems.
- VIew
- Renames views.
- ViewPort
- Renames viewport configurations.
