REDIR command (Express Tools)
Redefines hard-coded paths in external references, images, shapes, styles and rtexts.
Icon:
Redefines hard-coded paths for the following entities attached to the current drawing:
- external references
- images
- shapes
- rtexts
Note: Rtext entities in xrefs, rtext entities in block definitions, and images in Xrefs are not modified by the REDIR command.
Method
- Enter the old directory.Note: Type * to redefine all.
- Specify the new directory.
Note: In essence, the REDIR command is a search and replace command for paths.
Example:
: REDIR
Current REDIR mode: Styles, Xrefs, Images, Rtext
Find and replace folder names
Enter old folder, or '*' for all, or '?' to list references, or <Options>: D:\test\path1
Replace 'D:\test\path1' with: D:\test\path2
Searching for old folder: <D:\test\path1>
to be replaced with: <D:\test\path2>
Can not find font file: arial.ttf
SHAPE D:\test\path1\shape.SHX -> D:\test\path2\shape.SHX
Can not find shape file: arial.ttf
XREF xref D:\test\path1\xref.dwg -> D:\test\path2\xref.dwg
xref name: "xref"
Old path: D:\test\path1\xref.dwg
Reload xref "xref": D:\test\path2\xref.dwg
1 reference updated.
Searching for nested images ...\done.
IMAGE image D:\test\path1\image.jpg -> D:\test\path2\image.jpg
Searching for RTEXT entities ...
RTEXT D:\test\path1\txt.txt -> D:\test\path2\txt.txt
1 style/shape record(s) modified.
1 image(s) modified.
1 xref(s) modified.
1 rtext(s) modified.
Changes for some XREF entities are temporary.
Options within the command
- Options
- Opens the REDIR Settings dialog box that allows you to select which element types you want to replace the directories from.
