REDIR command (Express Tools)
Redefines hard-coded paths in external references, images, shapes, styles and rtexts.
Icon:
Method
- Enter the old directory.Note: Type * to redefine all.
 - Specify the new directory.
Options within the command
- options
 - Opens the REDIR Settings dialog box that allows you to select which element types you want to replace the directories from.
