REFCLOSE command
Closes the reference drawing editor.
Icons:
Closes the reference drawing editor, used to edit externally-referenced files in the current drawing session.
Note: This command can only be used after the REFEDIT command has commenced.
Method
There are 2 methods to close the reference drawing editor:
  • Save
  • Discard
Options within the command
Save
Saves the Reference drawing including the changes.
Discard
Saves the Reference drawing without saving the changes.
