REFSET command
Adds or removes entities from the reference (block or xref) being edited.
Icons:
Transfers objects between the RefEdit working set and host drawing.
Note: This command can be used only after the REFEDIT command has commenced.
Options within the command
- Add
- Adds entities from the drawing to the reference being edited.
- Remove
- Removes entities from the reference being edited; removed entities are placed in the drawing. Entities not in the reference are shown in gray.
