RENDER command
Opens the Render dialog box.
Icon:
Alias: RR
Opens the Render dialog box to create a photo-realistic rendering of the current drawing.
- Render destination
- Output size
Render destination
Specifies where the render will appear.
- Window
- Generates the render in a new window.
- File
- Saves the render to a file. Selecting the Browse button opens the Render output file dialog box.
Output size
Specifies the size of the rendering, in pixels. Larger sizes provide more detail but take longer to render.
- Width
- Specifies the width of the rendering, in pixels.
- Height
- Specifies the height of the rendering, in pixels.
- Same as viewport size
- Matches the output size or the size of the output window to the current viewport size.
