RIBBON command
Opens the Ribbon panel.
Opens the Ribbon panel in the current workspace. The Ribbon panel appears at the same size and location as it did before it was closed or collapsed. Like any other dockable panel, the Ribbon panel can be either floating, docked or stacked.
Note: The USENEWRIBBON system variable controls the display of the new Ribbon. By default, it is set to 1 (On).
