ROTATE3D command
Rotates entities around an axis in 3D space.
Icon:
Alias: 3R
Dynamically rotates 3D solids, surfaces, 2D entities, faces (planar, cylindrical, spherical, conical, and toroidal faces of a 3D solid or surface), edges, or vertices of a solid around an axis.
Note: When the face of a solid or surface is rotated, adjacent faces and edges are adjusted to preserve the correct solid or surface topology.
Method
You can rotate entities by:
  • Specifying an axis.
  • Using the geometry of an object as the axis for rotating the selected entities.
    • Hover over a line or linear polyline segment. Click when the entity highlights.
    • Hover over a 3D solid face, then move the cursor close to the edge you want to use as the rotation axis. A rotation arc and the rotation axis display dynamically. Click to accept the rotation axis.
Options within the command
Xaxis
Rotates the selection around the X-axis of the current coordinate system.
Yaxis
Rotates the selection around the Y-axis of the current coordinate system.
Zaxis
Rotates the selection around the Z-axis of the current coordinate system.
2Points
Defines the rotation axis by two points.
Entity
Uses the geometry of an entity to determine the axis for rotating the selected entities.
Click to start the rotation of the selected entity. It automatically selects a rotation axis if the cursor is over a planar face.
Last
Uses the last entered axis for rotating the entities.
View
Uses the current view as the axis for rotating the entities.
Note: The axis of rotation is parallel to the direction of view, passing through the picked point.
Rotation angle
Specifies the angle by which to rotate the entities.
Base angle
Allows you to define a new base angle.
Copy
Rotates a copy of the selection set.
Repeat
Creates multiple copies.
Disable connectivity mode
Removes the connectivity with adjacent entities.
Enable connectivity mode
Keeps the connectivity with adjacent entities.
Note:
  • If the HOTKEYASSISTANT system variable is on, press the Ctrl key to cycle between deactivate/activate the connectivity mode.
  • Geometric and dimensional constraints between selected entities are taken in consideration, as well as the lower and upper bounds parameters for 3D dimensional constraints. Constraints can be accessed and modified through the Mechanical Browser panel.
