RSCRIPT command
RSCRIPT command
Reruns the currently loaded SCR script file.
Note: Load and run SCR script files with the Script command.
Note: This command can be entered transparently during commands ( 'rscript).
Method
After a script file is loaded and run, enter RSCRIPT to run it again (short for "repeat script").
Related commands
  • DELAY command
  • RECSCRIPT command
  • RESUME command
  • SCRIPT command
  • STOPSCRIPT command
Related variables
  • CMDACTIVE system variable
  • EXPERT system variable
