RTEXT command (Express Tools)
Inserts or edits a remote text entity.
Icon:
The RTEXT command can be used to add frequently used text to multiple files. The command inserts the text of a .txt file to the drawing.
Options within the command
- Style
- Allows you to specify the text style.
- Allows you to enter the text style mask to list.
- Lists all available text styles.
- Height
- Allows you to specify the RText height.
- Rotation
- Allows you to specify the rotation angle of the RText.
- File
- Opens the Select text file dialog box that allows you to select a .txt file.
- Diesel
- Opens the Edit Rtext dialog box that allows you to use a DIESEL code.
