RTROT command
Rotates 3D drawings in a constrained manner, in real-time.
Icon:
Method
The constrained rotation cursor is displayed during real-time rotation. Hold down the mouse’s left button and then move the mouse to rotate the drawing in real-time.
Note:
- The ORBITAUTOTARGET system variable determines if the viewpoint rotates around your pick point or the center of the objects.
- The RTISOLATESELECTION system variable controls if the active selection is automatically isolated during real-time rotation.
Context Menu Options
Right-click to display the context menu to switch viewing mode.
- Pan
- Pans the drawing in real-time. Starts the RTPAN command.
- Zoom
- Zooms the drawing in real-time. Starts the RTZOOM command.
- Constrained sphere
- Rotates the 3D drawing in real-time. Starts the RTROTCTR command.
- Sphere
- Rotates the 3D drawing in real-time. Starts the RTROT command.
