SAVE command
Opens the Save drawing as dialog box.
Icon:
Alias: SA
Opens the Save drawing as dialog box to save data from the current drawing to a dwg, dxf, dwt or dws file.
File types available to save are:
- AutoCAD 2018 (*dwg)
- AutoCAD 2018 ASCII DXF (*dxf)
- AutoCAD 2018 Binary DXF (*dxf)
- Standard File (*dws)
- Drawing Template (*dwt)
- AutoCAD 2013 (*dwg)
- AutoCAD 2013 ASCII DXF (*dxf)
- AutoCAD 2013 Binary DXF (*dxf)
- AutoCAD 2010 (*dwg)
- AutoCAD 2010 ASCII DXF (*dxf)
- AutoCAD 2010 Binary DXF (*dxf)
- AutoCAD 2007 (*dwg)
- AutoCAD 2007 ASCII DXF (*dxf)
- AutoCAD 2007 Binary DXF (*dxf)
- AutoCAD 2004 (*dwg)
- AutoCAD 2004 ASCII DXF (*dxf)
- AutoCAD 2004 Binary DXF (*dxf)
- AutoCAD 2000 (*dwg)
- AutoCAD 2000 ASCII DXF (*dxf)
- AutoCAD 2000 Binary DXF (*dxf)
- AutoCAD Release 14 (*dwg)
- AutoCAD Release 14 ASCII DXF (*dxf)
- AutoCAD Release 14 Binary DXF (*dxf)
- AutoCAD Release 13 Drawing (*dwg)
- AutoCAD Release 13 ASCII DXF (*dxf)
- AutoCAD Release 13 Binary DXF (*dxf)
- AutoCAD Release 11/12 Drawing (*dwg)
- AutoCAD Release 11/12 ASCII DXF (*dxf)
- AutoCAD Release 11/12 Binary DXF (*dxf)
- AutoCAD Release 10 ASCII DXF (*dxf)
- AutoCAD Release 10 Binary DXF (*dxf)
- AutoCAD Release 9 ASCII DXF (*dxf)
