SCRIPT command
Runs a script file that contains a sequence of commands.
Icon:
Alias: SCR
Opens the Run Script dialog box to select a SCR file to run. After choosing Open in the dialog box, the script begins running immediately. You can press the Esc key to stop it.
A script file is a text file with a SCR extension that contains command lines to be executed at the Command line.
Note: The Run Script dialog box opens only when the FILEDIA system variable is set to 1; otherwise, the script name is required on the Command line.
