SCRIPTCALL command
Runs a script file that can nest scripts along a sequence of commands.
Opens the Run script dialog box to select a SCR file to run.
A script file is a text file with an SCR extension that contains command lines to be executed at the Command line and references to other script files.Note: The Run script dialog box opens only when the FILEDIA system variable is set to 1; otherwise, the script name is required on the Command line.
