SCROLLBAR command
Toggles the WNDLSCRL system variable.
Toggles the WNDLSCRL system variable to show or hide the drawing window scroll bars. You can launch this command at the Command line or within another command by preceding it with an apostrophe: 'SCROLLBAR.
Options within the command
- ON
- Turns On the WNDLSCRL system variable.
- OFf
- Turns Off the WNDLSCRL system variable.
- Toggle
- Changes the WNDLSCRL system variable to the opposite of the current setting.
