SETLICENSELEVEL command
Changes the available commands by setting the license type.
Runs BricsCAD® and/or Communicator for BricsCAD® at different license levels, which affects the commands that are available to the user. For the new license level to take effect, users must exit BricsCAD® and then start it again.
Method
There are two methods to change the license level:
- Change the license level of BricsCAD®.
- Change the license level of Communicator for BricsCAD®.
Options within the command
- Run BricsCAD at another license level
- Lite - runs BricsCAD® without 3D functionalities, except API and LISP.
- Pro - runs BricsCAD® without BIM and Mechanical commands.
- Bim - runs BricsCAD® with Pro and BIM commands.
- Mechanical - runs BricsCAD® with Pro and Mechanical commands.
- Ultimate - runs BricsCAD® with full functionalities, including BIM and Mechanical commands.
- Run Communicator at another license level
- No license - disables Communicator for BricsCAD®.
- Trial - stops running Communicator for BricsCAD® after 30 days.
- Full - runs Communicator for BricsCAD® normally.
