SETPROJECTLOCATION command
Adds a marker for the project location.
Sets the Project location point coordinates and angle.
Note: The Project location points coordinates and angle will be used in RVT and IFC import and export.
Method
Add a Project location point coordinates and angle to a new drawing or edit the Project location point information in an existing drawing.
Pick a point in the drawing or enter the point coordinates manually and specify an angle.
Note: The default values of the point coordinates and angle in a new drawing are 0. The current values are displayed in the Command line when running the command.
Toggle On/Off the visibility of the Project location marker by modifying the PROJECTLOCATIONVISIBILITY system variable's value (On by default).
Note: The True North indicator displays the NORTHDIRECTION angle measured clockwise, stored by the NORTHDIRECTION system variable, and is the same as the Survey location angle.
Options within the command
- Point
- Sets the X, Y, and Z coordinates of the point for project location marker.
- Angle
- Sets the angle between Project Y-axis and Drawing Y-axis, clockwise.
- Clear
- Clears the previously set point coordinates and angle (sets these values back to 0).
