SINGLETON command
Determines whether (or not) multiple copies of BricsCAD® can run at the same time.
Note: This command can be entered transparently during commands (‘singleton).
Options within the command
- Yes
- Allows only one copy of BricsCAD® to run.
- No
- Allows two or more copies of BricsCAD® to run.
Note: Some third-party applications run only in a single instance of BricsCAD®.
