SKETCHEDIT command
Edits feature sketches.
Alias: EDITSKETCH
Edits the sketches of features (EXTRUDE, LOFT, SWEEP, and REVOLVE) created when the CREATESKETCHFEATURE system variable is ON.
Note: These sketches can also be edited from the Mechanical Browser panel.
Method
Indicate the feature name (for example: Extrude_1), and enter the name of the sketch feature's block (or example: Sketch_1). A zoom and selection of the sketch feature being edited is performed.
When the Sketch/Path/Guides are modified, a preview of the new sketch feature geometry is displayed.
Note:
- Only the Sketch/Path/Guides that are being edited can be modified.
- During editing, you can still snap to other entities in the Model Space.
Run the SKETCHEDIT command again to close the session, restore the view, and update the actual sketch feature in Model Space.
Note: While editing, CTRL+S, SAVE, or CLOSE commands will close the editing session instead of saving the file.
