SMEXPORTOSM command
Exports a sheet metal solid to an Open Sheet Metal (.osm) file format.
Icon:
Reinterprets the supplied sheet metal model as an OSM part to be saved in an *.osm document.
The command is side-sensitive. It unfolds and scales the unfolded planes for each feature and then it connects these plane parts in accordance with the original model in the resulting *.osm document.
The .osm part is saved as mm- or inch-based, depending on the value of the document MEASUREMENT system variable. Document INSUNITS are considered for proper scaling.
The custom properties of all mechanical objects are imported into the OSM document and the OSM tags.
Note: You can set the accuracy of the approximation and the minimal edge length in the units of the document.
Options within the command
- add Decorations
- Exports non-sheet metal parts in the same .osm part.
- add 2D entities
- Exports 2D entities in the same .osm part.
