SMJOG command
Creates a jog on a flange or on cylindrical lofted bends that avoid the collision with the other extent and allowing to do the smallest cuts.
                Icon:
Method
- Jog on a flange
- Select an edge of a flange:
- Jog on cylindrical lofted bends
- Select an edge of the cylindrical lofted bend.
Option within the command
- Angle
- Sets the jog angle; the default angle is 45 degrees.
- Length
- Sets the length of the jog. When Dynamic Input Mode (DYN) is active, type the length in the dynamic input fields.
- Height
- Sets the height of the jog.
- Radius
- Sets the radius for the jog.Note: The starting point to measure the above dimensions is on the selected edge.
