SMLOFT command
Creates sheet metal part.
                Icon:
Creates sheet metal part with lofted bends and flanges from two non-coplanar curves.
                Options within the command
- fillets Radius
- Sets radius of fillet which will be created on straight lines connections. A radius can be specified or the minimum radius can be calculated regarding the thickness of the model by pressing enter.
- Thickness
- Sets model thickness.
- Single bend
- Creates only lofted bend feature without any flanges.
- Flanges with bends
- Creates a flange feature for each straight segment of the selected 2D entities or a lofted bend feature for curved segments.
- Alignment
- After setting all options, the alignment of the metal sheet loft can be chosen.
- thicken Inside
- Thickening direction is selected that way that 3D part is inside the selected 2D entities.
- Both sides
- Thickens at both sides of the selected 2D entities.
- thicken Outside
- Thickening direction is selected that way that 3D part is outside the selected 2D entities.
