SMREPLACE command
Replaces form features in sheet metal parts.
                Icon:
Replaces form features (including recognized ones) in sheet metal parts with form features from the built-in or user library. Displays the Select file for form feature dialog box where you can select a form feature file.
Options within the command
- Yes
- Replaces all form features of the same type as selected feature(s).
- No
- Replaces the selected form feature(s) only.
- parameters Mode
- Controls whether the parameter values of the form features that are replaced will be inherited or not. It is defined by the selected mode of replacement.
