SSX command (Express Tools)
Creates a selection set based on a selected entity using filters.
Method
Creates a selection set that contains entities similar to or exactly the same as the selected entity.
Note: To access the selection set for a subsequent command, use the Previous selection option.
Options within the command
- Block name
- Allows you to specify a block name to add or remove from the selection filter.
- Color
- Allows you to specify a color number to add to or remove from the selection filter.
- Entity
- Allows you to specify an entity to add to or remove from the selection filter.
- Flag
- Turns the Entities follow flag On or Off.
- Layer
- Allows you to specify a layer name to add to or remove from the selection filter.
- Ltype
- Allows you to specify a linetype name to add to or remove from the selection filter.
- Pick
- Allows you to select an entity.
- Style
- Allows you to specify a text style name to add to or remove from the selection filter.
- Thickness
- Allows you to specify a thickness value to add to or remove from the selection filter.
- Vector
- Allows you to specify an extrusion vector to add to or remove from the selection filter.
