STATBAR command
Toggles the STATUSBAR system variable.
Toggles the STATUSBAR system variable to show or hide the status bar. You can launch this command at the Command prompt or within another command by preceding it with an apostrophe: 'STATBAR.
  • On: turns on the STATUSBAR system variable.
  • Off: turns off the STATUSBAR system variable.
  • Toggle: changes the STATUSBAR system variable to the opposite of the current setting.
