STLOUT command
Export 3D solids and watertight meshes.
Exports 3D solids and watertight meshes in a format that can be used for stereolithography (3D printing).
Method
There are two methods to use STLOUT command:
- Export 3D solids.
- Export meshes.
Options within the command
- Create binary STL file
- Determines whether the output file is in binary or ASCII format.
- Select smoothness of objects exported to STL file
- Adjusts the quality of the exported entities.
- Low
- Exports with FACETRES = 0.5.
- Medium
- Exports with FACETRES = 2.0.
- High
- Exports with FACETRES = 10.
- Default
- The modeler properties from Settings are used.
