SUNPROPERTIES command
Opens the Drawing Explorer dialog box with Lights selected.
Icon:
Alias: SUN
Opens the Drawing Explorer with Lights category selected to view and modify sun properties in the current drawing.
Options within the Drawing Explorer
- General
- Status
- Toggles the sun on and off.
- Sun Angle Calculator
- Date
- Displays the current date. Edit the date to show the sun at a different time of year.
- Rendered Shadow Details
- Type
- Displays realistic shadows with softer shadows based on extended light sources, according to the Softness property.
- Geographic Location
- Reports location of the drawing on earth. To change the location, click the Edit button to access the Geographic Location dialog box; see GEOGRAPHICLOCATION command.
Context menu options
- New
- Loads additional light definitions into the drawing.
- Delete
- Deletes light definitions from the drawing.
- Rename
- Renames the light definition.
- Select All
- Selects all light definitions.
- Invert selection
- Deselects the current selection and vice versa.
- Set current
- Sets the selected light definition as current.
