SUPERHATCH command (Express Tools)
Hatches entities using images, blocks, external references or wipeouts as hatch pattern.
Icon:
Method
Opens the SuperHatch dialog box that allows you to select an entity as hatch pattern.
Pick an internal point where the hatch has to be applied.
Options within the command
Note:
- After the entity is selected in the corresponding dialog box, the Command line prompts you to enter the insertion parameters.
- During insertion, the Properties panel lists the Inserted Block Properties where you can directly edit parameters of Parametric, Mechanical, and BIM blocks.
- Edit inserted entity
- Allows you to change the parameter expressions for the parametric block you want to insert.
Continue to edit individual parameters, then press FINISH.
- Enter parameter name
- Specifies the name of the parameter.
- Enter expression
- Specifies the expression of the parameter.
- FINISH
- Finishes the editing of individual parameters.
- Rotate
- Allows you to change the rotation angle for the inserted entity.
- set Base point
- Allows you to change the base point for the inserted entity.Note: By default this is <0,0,0>.
- insertion Type
- Specifies the component type.
- Flip
- Allows you to flip the direction of the inserted entity.
- Multiple
- Allows you to insert multiple copies of the same entity by specifying an insertion point for each instance.
Continue to insert entities, then press Enter to end the command.
- Array
- Allows you to create an associative array of the inserted entity by specifying the base point, distance between columns, distance between rows and end point of the array.
- Direction
- Allows you to select an existing axial entity to define the direction.
- 2Points
- Selects two points to define the direction.
- Zaxis
- Selects the Z axis as direction.
- Object
- Allows you to select an axial entity.
- Last
- Uses the previous axis.
- View
- Allows you to specify a point on the view direction.
- Xaxis
- Selects the X axis as direction.
- Yaxis
- Selects the Y axis as direction.
- Single row
- Distributes entity copies into a single row.
- Rectangular
- Distributes entity copies into any number of rows.
- Columns
- Specifies the number of the columns.
- Rows
- Specifies the number of the rows.
- Placement
- Sets the distance between the entities.
- Accept
- Accepts the resulting array.
- Change target 3d solids
- Allows you to apply the inserted entity to existing 3D solids in the current drawing.
- Select target 3D solids
- Selects the target 3D solids.
- cleaR
- Clears the selection set to ensure no solids are affected by the inserted entity.
- Select all affected 3d solids
- All solids intersecting or touching solids in the BC_SUBTRACT and BC_UNITE layers of the inserted entity are affected.
- Scale
- Allows you to scale the inserted block.
- X scale
- Allows you to introduce the scale factor along the X axis. Enter a negative value to mirror the block about the Y axis.
- Y scale
- Allows you to introduce the scale factor along the Y axis. Enter a negative value to mirror the block about the X axis.
- Z scale
- Allows you to introduce the scale factor along the Z axis.
Note:
- Values larger than 1 make the block larger.
- 1 inserts the block at actual size.
- Values smaller than 1 make the block smaller.
- Values less than zero flip the block, like mirroring it.
- Corner
- Allows you to define the scale by selecting the opposite corner.
- Is this placement acceptable?
- Allows you to select another similar entity for insertion.
- Pick Internal point
- Allows you to pick an internal point or press Enter to select a boundary entity (such as a circle, polyline, or ellipse).
- Specify block First corner
- Allows you to set the first corner of the block in the drawing area, then specify the opposite corner.
- Specify xref First corner
- Allows you to set the first corner of the Xref in the drawing area, then specify the opposite corner.
