SUPPORTFOLDER command
Opens the operating system’s file manager at the Support folder.
Displays a file manager dialog box showing the contents of the Support folder.
Note:
- The Support folder holds many files that drawings and commands need, such as linetype patterns and tool palette libraries.
- Support folder paths are stored in the SRCHPATH system variable, and the default path is: C:\Users\%username%\AppData\Roaming\Bricsys\BricsCAD\V26x64\en_US\Support.
