TCIRCLE command (Express Tools)
Surrounds text, mtext or attribute definition entities with circles, rectangles or slots.
Icon:
Method
Select the entities and enter an offset factor.
Options within the command
- Circles
- Draws a circle around the selected text.
- Slots
- Draws a slot around the selected text.
- Rectangles
- Draws a rectangle around the selected text.
- Constant
- Surrounds selected entities with entities that are all the same size, the size of the largest enclosing entity.Note: For slots and rectangles of constant size, you can specify the dimensions that are kept constant: Width, Height, or Both.
- Variable
- Adjusts to the size of each selected entity, based on the offset factor.
