TINMODIFY command
Deforms or smoothens a selected TIN surface.
Icon:
Modifies a selected TIN surface by deforming or smoothening it or creates a new modified TIN surface.
Options within the command
- Deform
- Modifies the selected TIN surface or creates the deformable part as a new TIN surface.
- specify Contour
- Creates a deformation with a contour.
- select Entity
- Creates a deformation with an elevated chosen closed entity.
- draw Polygon
- Creates a deformation with an elevated polygon.
- Smoothen
Modifies the selected TIN surface by smoothening it between the indicated boundaries.
Creates a circular smoothening boundary by indicating a radius value and a location where you want the smoothening.
- select Entity
- Smoothens the surface part between the boundaries of an entity.
- draw Polygon
- Smoothens the surface part between the boundaries of a polygon.
