TPNAVIGATE command
Loads tool palettes at the Command line.
Loads a tool palette or palette group by name. If the Tool Palettes panel is not already open, then it is displayed (short for "tool palette navigation"). This command is meant for use by macros.
Method
There are two methods to load tool palettes:
- Specify the tool palette to display by entering the name of a palette.
- Specify the palette group to display by entering the name of a group.
